Closed Solved
Does the ASRock Z77 extreme 4-m fit any case?
Was wondering if the 4-m being smaller than the 4 mean that the slots for inputs smaller? Or will it fit any case?
8 answers Last reply Best Answer
More about does asrock extreme case
  1. Best answer
    The ASRock Extreme 4 Z77-M is a Micro ATX motherboard apposed to the Full Sized ATX board that the ASRock Extreme 4 Z77 is :)
    It will fit in any ATX case, it's only a little bit shorter than the normal Extreme 4, nothing else is different.
  2. You just won't use half the slots on the case because of the board being a micro board , everything else has to be the same size since all the video cards and other addon card have to fit.
    The boars has 4 slots and most mid tower cases have 7 slot openings so the bottom three will be not used.
  3. Best answer selected by instacallum.
  4. Thanks heaps guys :)
  5. You want to see funny, look at a ITX board in a ATX case :)
    http://www.overclockers.com/forums/showpost.php?p=6992084&postcount=4
    Oh my goodness...that looks...just...no words can describe that! LOL!
  7. If I had one of those older Xaser gaming cases. I would ITX it just to see reactions. Walk into a lan party with that
  8. This topic has been closed by Mousemonkey
Power Supplies Cases ASrock Components
