Solved
Help choosing psu
i am in the middle of choosing a psu i narrowed down to theese 2 which 1 should i get?
Corsair CX500
and
Silver Stone (80)plus series 500watt
system specs
i5 2500k
8gb corsair vengence ddr3 1600mhz ram
hd 7950
500gb storage
some led lighthing
thanks in advance
6 answers Last reply Best Answer
More about help choosing
  1. Best answer
    I'd go with the Corsair over the Silverstone, but I can't say for sure that it is better. Regardless, I think that a 600w PSU would be better, especially if you overclock.
  2. grab one of these as above post suggests get a 600w for for OC headroom later on
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
  3. That's a little more expensive than I'd go for, but it is a great PSU and its top-notch quality probably makes it worth the price for those who want to pay for it. Seasonic, in my experience, is about as good as a PSU brand can get, at least right now. I've also read that XFX is around Seasonic in quality too, but I'm not sure about that.
    All XFX power supplies are built to spec by Seasonic, a couple are just Seasonics with an XFX label
    Definitely "around Seasonic in quality"
    All right then, thanks for clearing that up.
  6. Best answer selected by tigeryeow.
Power Supplies Corsair Components Product
