Hello everyone, I've recently done a slight upgrade to my computer about a week ago, I removed my 9600GT and got a Gigabyte 7770OC, and the card messed up my Vista installation so I had to upgrade to Windows 7 Enterprise 32-bit. I've only played two games on the computer, the first being Arkham City, which I ran through DX9 at maximum settings and had a few FPS issues (wondered why but I figured it was badly optimized anyway). Then I installed Witcher 2 and ran it throug maximum settings fine as far as I can remember through the tutorial, then after the tutorial the game would barely run at 20+FPS intense scenes, I figured I'll notch the settings down, but there's still no change in FPS. My games would start out smoothly then the FPS would drop faster than a bowling ball in freefall. Anyways I figure the CPU is throttling my GPU, so I check the CPU temps and they're going over 80C on full load.
I haven't really cleaned or applied new thermal paste to my CPU since 2009, but what really got to me is why this all happened after installing Windows 7, maybe I had not noticed my temps in Vista but my 9600GT was using it's full power to run a game. I'm about to buy some thermal paste, but I'd like to know whether this was just a concidence or is my CPU running strangely after installing Windows 7. Can it be a BIOS thing, or my fan isn't running at full power? I've noticed the stock fan on my Gigabyte GX-X2B case isn't working either anymore. How do I fix the CPU temp issue and make the case fan work again?
Here's my rig:
GZ-X2B Case
Gigabyte 7770OC
4GB RAM
Q6600 Quad Core running at stock temp (2.4GHz)
600W PSU (sorry forgot the manufacturer but I will check)
Sorry for the long post, but any help would be greatly appreciated!
Here's my rig:
GZ-X2B Case
Gigabyte 7770OC
4GB RAM
