Will my parts fit in a Dell Dimension 4700 case? If not, what case?
CPU: i5 3570k
Mobo: ASRock Z77 Extreme4
GPU: NVIDIA GeForce 9800 GTX+ (planning on buying a second to SLI).
RAM: Kingston 8GB
PSU: Raidmax 700w
HDD: 500GB
I ordered everything new except for the GPU and PSU on Newegg; it should arrive tomorrow. Will all this stuff fit in my Dell Dimension 4700 case? If not, what should I buy?
I was thinking either
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075 or
http://www.amazon.com/Cooler-Master-Elite-Window-RC-430-KWN1/dp/B003O8J11E/ref=sr_1_1?ie=UTF8&qid=1337041456&sr=8-1
Does anyone have advice for me? This is my first build and I'm feeling pretty worried that it won't all fit in there.
4 answers Last reply
More about will parts dell dimension 4700 case case
  1. Full size ATX board, micro ATX case, no it won't work
    Cases are a personal choice
    Personally I wouldn't choose either of those for an SLI system
    2 budget models that I would
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
  2. I just bought a Rosewill one (5 star rated on Newegg with 1,000+ reviews). It's set to arrive in 3 days; the rest of my stuff will arrive in 1.
    Can I assemble the parts on top of the motherboard box on my desk, and use the computer with no case until the case arrives?
  3. I HIGHLY recommend not doing that. Why risk it. It is only a couple of days wait.
    Yes, it's called breadboarding and is done by most people with any experience
New Build Cases Dimension Systems Product
