Will the Corsair tx650m work for this build?
i2Perfect
55
I am looking into building a PC. I was wanting to know if the Corsair tx650m would power two gtx 670's in SLI, an i5 2500k OC'd to 4.0GHz on a Corsair H60, a Corsair force 3 120GB SSD, 8GB of 1600mhz RAM, and a 1TB HDD?
It is enough power, but it does not have enough PCIe connectors; you need a PSU with four, the TX650M only has two. You can use it if you're prepared to use adapters, but if you haven't bought it already I would recommend buying one that comes with the necessary connectors.
This not only has the necessary connectors, it is actually a better PSU than the TX650M:
Rosewill Capstone-650M ($100 @ Newegg)
http://pcpartpicker.com/part/rosewill-power-supply-capstone650m
Rosewill is better than Corsair? Rosewill has a history of offering powersupplies of questionable quality and value. They do make a few that are adequate and a few that are better but overall their quality is inconsistant.
Here's the quality with the required connectors
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151106
@OP
just make sure your cards require onnly 6 pin connectors, some GTX 670s have 8 Pin connectors.
