Solved
How to separate power and led? In mid build!
I'm upgrading an old case, and the front ports don't match the new mobo. The front has two USB's, mic and audio out. I'm not terribly concerned with the USB's, mic and audio, it would be nice to have it working, but how do I need to separate the wires for the power switch and led? It is a 14 hole connect configured the following way.
1234567
pins in column 1 as viewed are black over yellow,
column 2 - no wires
column 3 - black over none
column 4 - green over none
column 5 - yellow over none
column 6 - black over none
column 7 - blocked over none
It's an old Lenovo a61 case. Any help is much appreciated!
3 answers Last reply Best Answer
More about separate power build
  1. look into your motherboard manual it will have a diagram for the front panel connectors
  2. Best answer
  3. Best answer selected by scottyinfrisco.
New Build LED Monitor Systems
