Hello,
Building a new computer. Its been almost three years. My old stuff will probably be sold or salvaged for other stuff. Lots of new stuff has come out so an upgrade, based on my research should be pretty significant now. Since I bought my last computer we now have: 22nm processors, 28nm video cards, USB3, SATA3, PCI-E-3...etc. And now Windows 8 is around the corner.
My current build is:
CPU: Intel Core i7 920 D0.
RAM: OCZ Platinum 6GB Triple Channel; 3x2GB, CAS-Latency=7.
MB: Asus P6T.
PSU: Corsair 850TX.
SSD: Intel X25-M.
GPU: EVGA Nvidia e-Geforce GTX460 (768MB).
Nothing here is overclocked. Also for my case I want an HAF-912 Black Edition. Downgrade in size from the 932, but I do not need it. In addition, I am not upgrading my GPU yet, because I am waiting later this year for something like a GTX660. The 600s cards are too overkill for my requirements at this point as the 670 is the lowest one. Just a heads up as comparison to what I am planning to upgrade to as well as some reason:
What I plan on buying:
CPU: Intel Core i7 3770
PSU: Corsair AX650
^(Reason I want this PSU is, because of good brand name and secondly, I want a fully modular power supply. I already made a mistake with my other previous build having a non modular PSU and not using a lot of wires which create a huge hassle and mess inside the case.)
SSD: Intel 520 60GB SSD
^If anybody has any advice, recommendations or anything to say about these parts so far, please do. These are the parts I found to be the best from my research and lurking.
Here comes the part where I cannot decide. It involves the motherboard and that involves the RAM. My main motherboard decision is between the:
Gigabyte GA-Z77-DS3H
And
Asus P8Z77-V LX
Anybody have any recommendations? I currently have an Asus and its been a fantastic motherboard. I particularly like the BIOS. Anybody have experience of very recent Gigabyte/Asus motherboards to say which is better...or even if there is another one I should be looking at?
Now, due the gigabyte supporting up to 2400mhz ram and the Asus supporting just 1600mhz (without overclocking), I am deciding between two sets of RAM.
I will get these Mushkin Enhanced Redlines @ 1600Mhz if I get the Asus
And
I will get these G.Skill Ripjaws @ 2400Mhz if I get the Gigabyte
I am not dead set on any of these parts so if anybody has advice or recommendations to differ, PLEASE say it, thats why I'm posting here after all. In addition, is the upgrade from a 2.67Ghz i7 920 to a 3.4Ghz i7-3770 a big upgrade in terms of REAL WORLD performance?...Benchmarks show absolute domination by the 3770.
Thanks for any help.
-blackhawk1928
MB: Asus P6T.
PSU: Corsair 850TX.
SSD: Intel X25-M.
PSU: Corsair AX650
And
Asus P8Z77-V LX
And
-blackhawk1928
