Hello, the power button of my viesonic monitor got loosed while it is on the off position. Now i can't use it anymore as the power button is useless. How do I fix it?
Thank you for your reply
if the unit under warranty rma it and get a replacment. if it not in warranty then you have to unplug the monitor and let it sit power off and unplugged from the wall for 2 hours to let the caps in the power board drain for safty. you have to take the screws out the back of the monitor to open the case. with the case open you may be able to reseat the on switch. if not you may be able to replace it. the switch may have a part number on it that digikey or another online parts store or ebay may carry it. (if your lucly the on switch is not soilder on buy has blade plugs.
