Solved
Cabinet
hello mentor i pleased to say i buy new cabinet but if you help me to decide which cabinet good for mine i chose crosair 400r carbide or cm690 2 advanced or nzxt guardian 921 rb which one is best my budget is 100 $ only
6 answers Last reply Best Answer
More about cabinet
  1. Best answer
    Depends on what you want to do with your system in the future etc. and it also depends on how you want it to look, if you're concerned with cooling or expanding in the future etc.
  2. The answer is simple. Pick the one you like best :)
  3. +1^
    But, since you are on a budget, you can buy a perfectly functional case for half that amount.
    For example, the Antec 300 illusion model. $55 after rebate, with free shipping.
    Watch out for case shipping costs, cases are heavy and expensive to ship
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
  4. The case, in my opinion, should never take up more than 10% of your total budget. It's just unnecessary unless you really have some burning desire for a specific one :)
  5. well i think corsair 400 r is best but thanks for your suggestion my respect mentor
  6. Best answer selected by monu_08.
New Build Mentor Systems Product
