My spec:
I5 2500k
4GB+4GB Transcend RAM
Intel DH67BL Board
Cooler master extreme power plus 600w
I m on a plan to buy new graphic card probably HD 6670 or HD 6750 or GTS 450.
Please correct me if i am going wrong some where?
Max power required for 6670 is 65 watts and 6750 requires 85 watts as per the specification.Cooler master extreme power plus 600w has 2 x 12v rail with 18A+18A .So, with single rail connected to motherboard, i get 18x12=216watts. From the specification Cooler master extreme power plus 600w is 70% efficient. If so, then 70% of 216watt = 151watt. I5 2500k needs 95watt as per specification which leaves 56watt* for GPU. Will this be sufficient to support HD 6670 or HD 6750?
In case of GTS 450, after a search in google i found it has pcie 6 pin connector. So independent power input can be connected direct from PSU, by which card can get around 75 watts. So 75+56*(remaining from 12v rail)=131 watts but max power used by GTS 450 is 106watts.
To my understanding i hope GTS 450 can work with my PSU. But in many forum i see people using HD 6670 , HD 6750 or higher card with Cooler master extreme power plus 600w.how they are using it?
I never had any experience with graphic cards so far, i like know more about pcie 6 pin connector on latest graphic cards ?
I connected one 12v with motherboard and another 12v rail hanging useless. Is there is way to make use of the unused 12v rail with 18A ? So that i get 18A+18A=36A.
Since this is my 2 month old rig i cannot go for a new PSU. So which card should i choose?
I5 2500k
Intel DH67BL Board
