RAM gets hot because its always in use, the same with the WNIC, if you have it turned on it will always look for a network and that makes the chips hot, and when you are connected it transfers data most of the time and that makes it hot aswell.
Most chips get hot (Chipsets, CPUs, GPUs, Sound chips, network controllers and so on).
