Nokia 3595 problem/question...
Archived from groups: alt.cellular.nokia (More info?)
Hi all,
I recently purchased one of these phones new. The power button seems
to take a lot of force (hard downward pressure no click) compared to a
friends 3590 (light force and switch has a click to it) . Can anyone
tell me if the 3595 power switch is supposed to be considerably
tighter than a 3590?
Thanks for any help/suggestions!
3 answers Last reply
More about nokia 3595 problem question
  1. Archived from groups: alt.cellular.nokia (More info?)
    On Thu, 20 May 2004 22:08:23 -0400, Matt Davis <none@all.com> wrote:
    >Hi all,
    My 3595 turns on and off as you describe but so did my old
    8260. I've never had a 3590.
    Guess they won't be turned on or off accidentally!
    Jack Mac
  2. Archived from groups: alt.cellular.nokia (More info?)
    >Subject: Nokia 3595 problem/question...
    >From: Matt Davis none@all.com
    >Date: 5/20/2004 9:08 PM Central Daylight Time
    >Message-id: <rroqa0p0i2irar51n2p0k9v7dqn4kpa61u@4ax.com>
    >Hi all,
    There is a click if working correctly, switch is below the small circle in the
    center of the rubber pad, use a fingernail or tip of a key or something to
    press the circle ...
  3. Archived from groups: alt.cellular.nokia (More info?)
    I Thank you, and the other gentleman, who replied!
    >>Hi all,
Nokia Power Switch
