Will this budget system work?
I am a new builder.
Budget Range: less than 500 before rebates
System Usage from Most to Least Important:gaming
Parts Not Required: keyboard,mouse,os,monitor
Preferred Website(s) for Parts: newegg perferred unless other places have lower prices
Country:USA
Parts Preferences: AMD/Ati
Overclocking: Might do lite overclocks
SLI or Crossfire: No
Monitor Resolution: Dont know and dont care. (currently game on all low settings so im used to low resolutions)
Additional Comments: I did make it a bit easier and picked out some parts and put them on a wish list
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=16653811
Worried about the psu not being good enough and not having certain wires
My first build and i dont want it to fail becouse i bought wrong part :cry:
2 answers Last reply
More about will budget system work
  1. It's not a bad list of parts but the issue I have is the case/power supply combo and $60 for both , while a great deal is not something I would go with. You also need a dvd drive.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811154109 -$22
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016 -$45 after rebate.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 -$18
  2. I install everything through a USB drive so no need for DVD drive. (I could save for a good sound card for my dusty 5.1 system)
    I was hoping not to use that case because of bad reviews but ill use it.
New Build Systems Product
