Hello,
I've built my gaming rig a day ago and now I'm having troubles.. I'm posting this thread hoping if you can share your insights.
I believe I've done all assemblies correctly, however, I hear a loud fan like noise .. and I believe it's from my GPU - gigabyte hd 6850 windforce, though it works well. Is there anyway I can reduce the noise? Or do you think maybe the noise coming from another part?
As well, my ethernet connection is keeps disconnected , especially when I just turn on the pc.. Is it possible that my router is broke or do I have defective Network card? the router is about 4~5 years old. My laptop sometimes has that problem too.
Lastly, could you advise how to maintain the newly built pc? like do you think it's a good idea to use CCleaner or perform disk cleaner, etc? I'm using Avast free. Is there any good for free (I'm planning to subscribe kaspersky later on..)
Thanks guys! Cheers
Thanks guys! Cheers
