Hello,
I recently bought XFX's 6870 graphics card along with a continuous 700w PSU to power it, since it apparently requires a minimum of 500w.
Well, I removed my previous PSU and hooked up my new PSU first to make sure that the PSU was fine. Everything worked great so I removed my old graphics card (ATI 5670) and inserted the 6870. It said that it requires two PCI express connectors (6-pin) and the new PSU that I bought has two 6-pin connectors.
I hook the two 6-pin connectors to my 6870 card and start it up. My monitor acts like I haven't plugged anything in. It's just blank as in not registering instead of blank because of an underpowered graphics card.
Anyways, I checked the manual pamphlet thing that came with it and it states that I need two separate PCI lines but my 700w PSU has only one PCI line that splits into two 6-pin connectors.
So I'm wondering if I need to get a new PSU all because I only have one PCI line instead of two or if this is a problem related to my monitor that, for some reason, won't register my 6870.
My graphics card and PSU specs are as follows:
Old card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125339
New card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
New PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817152042
And for those of you who are asking, yes I understand that the 6870 requires the DVI cable to work. I've tried both DVI/DVI and DVI/VGA with my monitor but both times my monitor acted as if I hadn't plugged in the cable. It just wouldn't acknowledge my new card.
Also, this is not an issue with my motherboard or my PCI Express slot at all. I've narrowed the issue down to either being:
A. My PSU doesn't have two separate/independent PCI lines with its own 6-pin connector. (Though I don't think it should matter if I have more than enough power left in my PSU - remember minimum watts for the 6870 is 500w and I have a 700w continuous.)
B. My monitor has some sort of issue that I have no idea how to fix. (Don't suggest HDMI because my monitor doesn't have ad HDMI port. By the way, my monitor is around 23".)
Will someone help this poor soul?
