Power supply incorrect output
  • Antec
  • Power Supplies
  • Motherboards
  • Components
Last response: in Components
September 6, 2012 5:03:09 AM
Hello guys,
Recently my pc start giving BSOD, and 2 days back when I restarted it, it would not turn on. Only green light on motherboard stay on, when I press power button nothing happens, no beeps. No fan spins at all.
I have tested my power supply with multi-meter and found that PSU is not working properly, its turns on but giving wrong output. Please see below my results.
Yellow=+12|Mine=15.40 Red=+5|Mine=6.57 Orange=+3.3|Mine=4.34 Blue=-12|Mine=14.50 Purple=+5|Mine=6.36 Gray=+5|Mine=6.55
i sent my PSU for RMA and now overclockers technician decleared that PSU is working 100% fine, i just asked them to plz check PSU incoorect output, as this is the cause for no response for my MB or CPU, any suggestion for ur side?
a PAU with these wrong output can be dangerous?
Support Details:
Motherboard: ASUS P8P67 PRO
Motherboard Driver:
Motherboard Chipset: P67
Motherboard BIOS: 2303
CPU: INTEL 2500K
Memory: G.Skill F3-17000CL9D-4GBXL
Memory Latency: 9-11-9-28
PSU: Antec TruePower New Modular 750W
Graphics: EVGA GTX 670 FTW
Graphics Driver: 301.42
Sound Card: ASUS XONAR DX
Sound Driver: 7.12.8.1794
Operating system: WIN 7 Ultimate 64 bit SP1
Regards
More about : power supply incorrect output
a b ) Power supply
a b V Motherboard
September 6, 2012 7:22:13 AM
First make sure the multimeter is calibrated, (there an internal battery inside of multimeter, if the battery weak the measurement can go off)
If those reading are correct it will very bad for your system...
Try contacting the antec support take a picture of the multimeter if u had to...
September 6, 2012 8:24:44 AM
Thank u for reply. can a PSU with these wrong output power up a system, perhaps this PSU has already killed my MB and Overclockers tachnician is able to get a post. perhaps PSU will kill overclockers MB if used for a long time? just wanna confirm. thanks
a b ) Power supply
a b V Motherboard
September 6, 2012 9:44:47 AM
different mobo had different tolerance so it hard to tells, but constant high input makes the voltage regulator work harder and produce more heat...
how fast it will fail? dunno..
but since all rail had higher voltage, Try calibrate the multimeter first...
