Guys, i'm trying to connect 2 pcs from pc A to pc B directly using a crossover cable CAT5.
IPv4 settings as below:
pc A is windows XP
IP: 192.168.2.1
Gateway/DNS server: 192.168.2.2
pc B is Windows 7
IP: 192.168.2.2
Gateway/DNS server: 192.168.2.1
Subnetmask is the same for both : 255.255.255.0
From pc B, i could locate the shared files on pc A but not the other way around.
In local area games like dota. I cannot see each other's host game.
Any advice?
By the way,
Will this be easier if i buy i multiple port switch to connect the pcs?
I plan to connect 5-10 pc together, mostly laptop. Wired or wireless better?
If wireless what criteria should i choose as most of my laptop connections are G only.
What is the maximum number of connections for a wireless G router?
Need help on these 2 problems.
Much thanks.
pc A is windows XP
IP: 192.168.2.1
pc B is Windows 7
IP: 192.168.2.2
Any advice?
By the way,
Much thanks.
