Hello,
I just installed 3570K with arctic solver 5 and stock cooler on asrock z77 extreme4 mobo yesterday. I noticed (using realtemp, coretemp) that the idle temps of the cores are around 44 degrees. using prime 95 torture test, they go up to 95 degrees within 5 minutes. Any guess what is wrong? I made sure that the stock cooler is properly installed and the thermal paste covers the whole CPU surface.
I contacted intel via chat - they are saying this software is not supported and the temps I am hitting is perfectly normal under load since I am not letting it to cool down under stress test.
I am a little confused because I have been reading all over the internet that stock cooler is fine if you dont overclock and the load temps should be at most around 70 to 80 degrees.
