Solved
Will these parts function together? - Full custom build
Last response: in Systems
Hi everyone,
I think I've got my new gaming desktop setup just the way I want it, but I want to make sure all of these parts are compatible. I'm pretty sure they are. Your help is greatly appreciated. Oh and I left out the DVD drive intentionally. Thanks! :)  Here is the list:
--Motherboard:
ASRock Z68 PRO3 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
--CPU:
Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32100
--GPU:
MSI N550GTX-Ti-MD1GD5 GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
--PSU:
LOGISYS Computer PS600XBK 600W ATX12V SLI Ready Power Supply Black w/ 120mm Ball Bearing Fan
--Memory:
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-4GBXL
--Hard Drive:
Seagate Barracuda ES ST3750640NS 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
--Cooling:
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
--Computer Case:
APEX SK-393-C Black Steel ATX Mid Tower Computer Case
Best solution
Homebuilt system Master
Hmmm , this looks familiar... and yes I still think it will work well together. If your husband is not going to overclock the cpu then you don't need the Artic Cooling Freezer , the i3-2100 cpu will come with a cpu cooler. You could however pick up some thermal compound for the cpu , I always use this one;
Arctic Silver 5 Thermal Compound - OEM
$11.99
Ask the community
