Help requested in picking PSU
Hi.
I know that this request is probably as unoriginal as it gets, but I'm really stumped, and I'd appreciate your help.
I'm building a new system, for work, web, gaming and such.
My mind is pretty set on this setup:
i5-3750k
Gigabyte Z77-D3H
8 GB Corsair Vengeance
Gigabyte HD7850 2GB
Sandisk 120GB SSD
WD Caviar Green 1TB HD
Blu ray Drive
Zalman Z11 Plus
The only thing missing is a PSU. Since there are so many companies, lines and models, I just can't pick one.
According to various calculators, this system would need a PSU of 350-400W.
I wanted to take a 500-550W one, just to be on the safe side, and I think that around 50GBP would be a fair price.
I'd really appreciate your comments on this matter. Which model would you recommend?
Many thanks,
Idan
21 answers Last reply
More about help requested picking
  1. +1 to the XFX Core 550W
  2. A 380w psu would be plenty for that system.
    XFX is a great brand made by Seasonic, highly recommended and 5yr warranty.
    True story and if the OP wanted to save another 15, then he could go with the XFX Core 450W: http://www.scan.co.uk/products/450w-xfx-pro-core-edition-p1-450s-u2b9-85-eff-80-plus-bronze-sli-crossfire-eps-12v-fan-atx-v231-psu
    Yep, but the guys who want twice as much power as the system will use will cry about the bunnies and kittens that die when you "overload" a psu
    Noticed your sig says something about Tribes Ascend, how is it ? I've got half a dozen codes from cpu purchases and haven't bothered with them
    :lol: :lol: :lol:
  6. Actually I would not suggest to take something less than a quality 500W PSU like XFX or Corsair: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
    One friend of mine builded a lighter desktop than yours and used a 500W from CM's extreme power series (mistake as the CM's GX series are meant for gaming desktops) and he experienced crushes and black screens about a couple of weeks before he figured it out. Now he changed it with a Corsair 700W Gaming series and he is fine :P
    The point is that taking a bigger than required PSU is not a big deal, but taking a smaller is.
  7. Idanyd said:
    Hi.
    i5-3750k
    Gigabyte Z77-D3H
    Gigabyte HD7850 2GB
    Sandisk 120GB SSD
    Blu ray Drive
    Zalman Z11 Plus
    Many thanks,
    Idan
    I have a 3570k, 7850, 8GB corsair vengeance and HD 7850, and i have a XFX 550w Core Edition. The only bad thing is it is not modular.
    That's probably because the CM EP+ series of PSUs are craptastic and overrated so CM can overcharge. A few reviews:
    1. http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-500-W-Power-Supply-Review/728
    2. http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-550-W-Power-Supply-Review/969
    3. http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-600-W-Power-Supply-Review/1034
  9. Thanks, guys.
    I was thinking in the line of xXStavrosXx (Nothing to do with fluffy bunnies. It's just much more of a hassle to change an insufficient PSU to a stronger one, rather than buying a stronger one to begin with), but I'll take your words that a good 450W is enough.
    Frankly, I was toying with the idea of buying a modular PSU, but I guess that there aren't any modular ones in XFX 450w's price range, right?
  10. Probably not but you might be able to track down a good deal on an OCZ ModXstream 500W after mail-in-rebate.
  11. A couple of options for modular but they do cost more:
    1. Antec Neo Eco 20W: http://www.scan.co.uk/products/520w-antec-neo-eco-0-761345-285209-modular-82-eff-80-plus-bronze-sli-crossfire-eps-12v-fan-atx-v23-p
    2. Be Quiet! Pure Power 430W: http://www.scan.co.uk/products/430w-be-quiet!-pure-power-l8-bn180-modular-88-eff-80-plus-bronze-sli-crossfire-quiet-fan-atx-v231-ps Mixed reviews on the higher rated PSUs in this line; some good but some are just OK. I'd stick with the XFX Core 450W.
  12. Rugger said:
    This seems kind of odd
    **Please NOTE: does not include power cord and modular cables**
  13. I know none of them come with the power cord, but it's really odd that this unit doesn't come with the modular cables. I'd call to verify and wouldn't get it if it didn't come with the modular cables...the extra cost for cables would make it not worth the money.
    Makes me wonder if they are actually selling the modular version or not
  15. It definitely seems a tad shady...
  16. Excellent PSU but Id go with the XFX Core 450W for the same price and longer, 5 year warranty: http://www.scan.co.uk/products/450w-xfx-pro-core-edition-p1-450s-u2b9-85-eff-80-plus-bronze-sli-crossfire-eps-12v-fan-atx-v231-psu
  17. Idanyd said:
    Gotta be something in the water, the C indicates the non modular version
  18. And apparently the Antec has only 80 Plus, in comparison to the XFX's Bronze.
    So, the XFX 450W it is.
    Thank you all for your help :)
  19. Glad we could help - enjoy a great PSU!
Power Supplies Components Product
