T thently Distinguished May 10, 2007 1,982 7 20,465 Jan 21, 2012 #2 Um more info... I assume you mean you pored water on your laptop.. If that is the case you are out of luck mate. Most likely your sound card is tits up... Go get a USB or PCMCIA ar whatever slot you have sound card and move on. Thent Upvote 0 Downvote
