Ok, here's my issue. I've added water cooling to my system and it's become unstable. It was fine before I added it and I ran the WC for 6 hours with no power to my system for testing before adding power after there were no leaks.
My specs are in my sig but I've added five 120mm fans (total of six led 120mm fans and 2 90mm fans), 2 cold cathodes and a pump. I also have 3 hdd's, one optical and a fan/light controller.
If I take the fan controller and 3 of the 120mm fans out of the system then I'm stable again. This makes me think it's a power issue. Anyone have similar issues and is my 600W (35A on 12v rail) insufficient?
If the power is the issue would you recommend a second psu for the fans/pump/hdd's/optical/fan controller or getting a beefier single psu? I was looking at the pc power and cooling 1kw psu but it's costs more than 3 good 600w psu's and since I already own one 600w psu adding a second would only cost $150 whereas the 1kw is almost $500. How many amps on the 12v rail do I need? The psu calculators don't really consider amps just watts.
