Help on new build
Hi guys,
im planning on building a new gaming PC in a week or two, parts are listed below,
Mobo Asrock Z77 Pro3
RAM G.Skill Ripjaws X 4Gx2 DDR3 1600
GPU Sapphire Radeon HD 7870
CPU Intel Core i5-3570K
HSF Coolermaster Hyper 212 EVO
HDD WD Caviar Black 1TB
Case Coolermaster HAF 912 Advanced
PSU Antec HCG 520
Monitor LG E2251T-BN
any thoughts? could i go for caviar blue or seagate 7200.14 to save $30? would the psu be enough?
any help would be greatly appreciated, thanks :)
11 answers Last reply
More about help build
  1. http://www.tomshardware.com/forum/261222-31-build-advice
    try to follow this format so we can understand the type of build more
  2. sorry about that,
    i will be getting the new build in a week or two, budget is around $1200, i do plan on overclocking both my cpu and gpu but no sli/cf, see new list below:
    Asrock Z77 Pro3
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=19864
    G.Skill 4Gx2 DDR3 1600
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=19632
    i plan to oc this a bit
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=19778
    Intel Core i5-3570K
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=187_346_1184&products_id=20138
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=18670
    i plan on oc the cpu to 4ghz+ using the cooler
    WD Caviar Black 1TB
    should i go for blue or seagate 7200.14 to save some money?
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=13660
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=15892
    Antec HCG 520
    will this psu be enough?
    http://www.pccasegear.com/index.php?main_page=product_info&products_id=15135
    LG E2251T-BN monitor
    will buy this at local store
  3. YzGHOSTjC said:
    sorry about that,
    Asrock Z77 Pro3
    Intel Core i5-3570K
    WD Caviar Black 1TB
    Antec HCG 520
    its a nice build i can probably tweak some stuff around to make it cost less but i need to know if USA, CA, etc
  4. thanks, i live in Australia and i will be buying from my local store, prices are almost identical on the sites i posted.
    according to my comparison, cases and PSUs are generally more expensive here and high end GPUs are also more expensive
  5. not much i can do for the MOBO it is really nice reason why its not as popular is because it doesn't let people have the SLI/CF option since it has only 1x3.0 slot
    the Case you put up there has a lot of space and a nice cooling solution with the fans inside you can make it cheaper but that is if you desperate to save money
    i would go for Seagate to save some extra
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=210_344&products_id=19747
    what i am trying to do is actually add an SSD inside for boot up
    everything is fine 500 watts is enough for a no sli/cf config
    if anything add an SSD for faster boot but that is just optional 2
  6. thanks for the advices.
    I was considering buying Seagate but i heard people saying their new 7200.14 drives have higher noise than previous generation, how is caviar blue?
    I will consider buying a SSD for boot drive and for several programs
  7. either one works really if you are getting a SSD you might as well go a bit cheaper on the HDD since loading will mostly be from SSD
    if you want less noise for more money you can that is all you
    SSD the least i GB i would say is 60-64 GB just for boot up
    if you want apps inside i would say 120-128GB SSD a bit more pricey though
  8. thanks for the help, i have decided to go for a caviar blue and a SSD.
    I'm looking at intel 520, crucial m4 and ozc vertex 4, any suggestions?
    one followed up question, would SRT be a better option?
  9. YzGHOSTjC said:
    sorry about that,
    Asrock Z77 Pro3
    Intel Core i5-3570K
    WD Caviar Black 1TB
    Antec HCG 520
    Nice build m8. Everything looks good.
    good to know :)
    m4 is very reliable you just have to upgrade its firmware to get better performance
    intel 520 has very very good speed and reliability but it is very pricey compared to m4
    ozc 4 is the newest, i am not very familiar with their new Indilinx driver but right now it is very cheap, cheaper than m4 currently
New Build Systems
