I'm building a new computer right now, and need opinions/advice. I want to have a very clean look inside the case. I have a Antec Three Hundred Two case with two 120mm fans in the front, 120m in the back, 140mm on top, and soon to be another 120mm on the side behind the mobo. All fans use 3 pin connectors and have their own speed control switches. I have a ASRock Z77 Extreme mobo. I don't want to have all these fan power cables making my computer look messy inside.
I was thinking of using 3 to 2x 3 pin Y splitter cables like these:
http://www.ebay.com/itm/3-2-x-3-Pin-Black-Sleeved-Y-Splitter-Computer-Case-Fan-Power-Adapter-Cable-/160802507274?pt=US_Power_Cables_Connectors&hash=item2570938a0a
Is it safe to use these? I've read mixed opinions on using these, may not be good for your motherboard, and can possibly damage it?
or
Something like this, and hiding it in the case somewhere. Only downside is, the fans will run at max speed/power 24/7? Because the mobo can't control it. Will the fan speed switches on each individual fan still work with this?:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812195004
What do you guys think my best option is? If you know another way to conceal these cables, please let me know!
Also, does anyone have any links for tips and tricks on cable management?
Thanks!
or
Thanks!
