wr6133 said:
Overclock the CPU see if it improves
I dont doubt there is a bottleneck but that doesnt fully explain that you should be getting VASTLY higher FPS than that
Are all temps etc within spec?
Thanks for the response. all of my temps are solid, yes. and i shouldntve said 45fps stable, i meant to say 45fps ish minimum. I'd like 60ish to be my minimum with rarely dropping below 45. i consistently drop below 45fps currently. usually i can get between 50-90 otherwise, depending on the map/whats going on/etc.
i'd be okay with this if i wasnt trying to record myself playing, but since i am, my frames take a drop to unenjoyable levels. i'm consider overclocking my cpu since im sure thats the problem but i only have its stock fan atm and i have zero experience with overclocking a cpu.
Encoding video takes a lot of CPU processing power.
I recommend looking into one of Intel's 6 core Sandy Bridge-E socket 1156 CPUs such as the i7-3930k for $560. The other choice is the i7-3930X, but you will be paying a very steep price for only an extra 100MHz; $1,030.
You also need a very fast graphics card like on OC'ed GTX 680 assuming you want to max out the graphics to "ultra". While the GTX 680 can manage to get around 70FPS - 75FPS, that is generally the peak or max FPS which is different from the minimum FPS. Therefore, it is still possible (very likely in fact) that your FPS will drop below 60FPS. Which means you need more GPU processing power.
Don't get caught up with an absolute minimum of 60FPS unless you are willing to spend over $2,000 for a complete system. said:
also thanks for the response. I didn't know that encoding video takes a lot of cpu power! unfortunately i don't quite have the budget to get a $500+ processor but <$300ish is possible. Maxing out graphics is not a priority here, i'll probably be playing on lower graphics just to maximize my frames (i'm a competitive player). that being said, i'm pretty sure 2 crossfired 7850s beats out a 680; regardless though, i'm sure i have enough gpu power as it is.
is there a particular intel processor you would recommend me within that budget though? thanks again for the response i appreciate it
