Approximate Purchase Date: ASAP
Budget Range: $1000-1300
System Usage: Heavy Photoshop usage including 3D objects and 3D rendering. Usage of multiple Adobe and 3D animation programs for web and graphic design. Occasionally will be used for gaming, but it's not the priority.
Country: Greece (Newegg links are welcome, however)
Overclocking: Perhaps in the future, currently not knowledgeable enough
SLI or Crossfire: Likely in the near future, not my current priority, but I'd like to be SLI proof.
CPU: Ivy Bridge i7 3770k
MOBO: Asrock Z77 extreme4-M (mATX). Supports SLI and Quad SLI
RAM: DDR3 16GB 1600mhz (Probably 2x8GB, in case I ever need 32GB of RAM)
GPU: Using my old 9800GTX+ until I decide on a new one.
CPU cooler: Cooler Master Hyper 212
I'd like advice on what PSU and Midtower to get that will be able to support/fit two GPUs that are similar in size to the GTX580.
If you guys have any more recommendations unrelated to my question, they are also welcome.
