3x 3pin case fans controlled by 1 PWM Mobo header?
Last response: in Components
- Can i use a pwm splitter to control 3pin case fans woth the cpu 4pin header?? Forum
- SolvedUse a 2-pin ATX fan on a 3-pin mobo PWM controller? Forum
- Solved2x 3-pin fans in 1 system fan header? Forum
- SolvedSwifttech mcp655 modified for pwm (by frozen CPU) with a 3-pin fan controller? Forum
- Fan Controller like NZXT Sentry 3 or PWM headers on mobo and GUI? Forum
- Why can i control 3-pin fans like PWM fans? Forum
- Solved2 pwm fans 1 header Forum
- Help connecting 2x 3pin fans to 4pin mobo header Forum
- SolvedCan i hook a 3pin fan to a 4cpu CPU fan header on my mobo? Forum
- Solved4pin pwm fan connected to 3pin fan controller Forum
- SolvedI have a Rosewill Challenger case with 3 fans but my mobo only has 2 chassis headers. If I run 1 fan on molex would that affec Forum
- PWM 4pin cpu heat sink fan/ 3pin cpu fan mobo Forum
- SolvedCan i manually control the speed of my two 3-pin case fans if they are plugged in 4-pin slot? New to pc's - Pls help! :) Forum
- Using 3-pin Y-Splitters to Control 2 Fans on One Header Forum
- SolvedDo case fans need to be PWM for control with a fan controller Forum
- SolvedCan 3-pin fan headers control 3-pin fans? Forum
- Need to control 6 3-pin fans with 2 fan headers using Speedfan Forum
- SolvedCase with 2 case fans but only 1 fan header on the motherboard Forum
- SolvedIs it okay to plug in a 3-pin case fan plug into a 4-pin socket on my mobo? Forum
- Case has 2 x 3-pin connector fans, motherboard has 1 x 4-pin connector. Forum
- More resources
Read discussions in other Components categories
