Approximate Purchase Date: In the next 2 weeks
Budget Range: Looking for the best avaliable options, none really
System Usage from Most to Least Important: Gaming
Preferred Website(s) for Parts: Any
Country:US
Parts Preferences: by brand or type: Any
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1920x1080)
Additional Comments: Have most of it picked out and bought, just need some advice on a case and PSU
Already Bought:
CPU:Core i5 3570K 3.4GHz LGA 1155 Processor $190
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
MoBo:ASRock Z77 Extreme4 LGA 1155 Z77 ATX Intel Motherboard $90
http://www.microcenter.com/single_product_results.phtml?product_id=0387554
RAM:Crucial 8GB DDR3-1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit (Two 4GB Memory Modules) $40
Optical:Sony Optiarc 24X DVD Burner, Bulk Package 24X DVD+R 8X DVD+RW 12X DVD+R DL $22
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118067
HD:Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $85
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
$427 so far
Leaning towards:
GPU:GIGABYTE GV-N670OC-2GD GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card $400
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125423
PSU: Either a Rosewill Hive 650 or 750, need advice for that.
Case: Need suggestions PLZ
Country:US
Overclocking: Maybe
Already Bought:
$427 so far
Leaning towards:
