Sound Issue
Last response: in Windows 7
Hello,
Asus M4A88T-V EVO
Onboard sound Realtek
Windows 7 64 bit
I recently replaced the power supply on my system, and when I fired it back up, no sound is coming from the speakers. I double checked the speakers were working, and they are. I downloaded updated drivers from realtek, even reverted and let windows install it. Checked BIOS to make sure onboard sound was enabled. Tried all the unplugging and replugging tricks. I do get a signal that the CPU is recognising sound in the mixer, but nothing comes out of the speakers.
Ideas?
More about : sound issue
Related ressources
I've run the test and no sound correct. The system recognizes the speakers, and in volume control, I am getting a signal, indicating that sound is being recognized, but none comes out.
Driver Expert
Power supply Expert
Windows 7 Expert
do you have headset that you could try in those connector and see if you got sound adding this check if the front panel audio is connect to motherboard in mobo
all connections are good. Realtek control panel recognizes a connection on both back and front panels. I'm sensing an issue with my BIOS? But I'm not an expert enough on BIOS configs to know for sure. I do know that the audio is enabled in BIOS.
Driver Expert
Power supply Authority
Windows 7 Authority
In your BIOS, all you do is enable/disable the on-board sound. Really no other configuration items on most modern rigs. I am still thinking about this one.....
Driver Expert
Windows 7 Authority
...On second thought, some systems let you select AC '97 or HD Audio mode. Your FP connector needs to match the mode you have chosen. Many cases use front panel connectors that have both AC '97 and separate HD Audio connections on them.
If, you can select the mode in the BIOS (usually in the integrated devices section), make sure your FP connector matches the mode.
My MOBO does have both HD and AC 'Mode, and the case has plugs for both. HD is plugged in and enabled. I'll try plugging in the AC'97 and enabling that option in BIOS. Try anything at this point.
I tried the ASUS driver download, and the one from realtek. I just did the switch to AC '97 and no dice. I think the onboard sound might just be fried. SHould I invest in a soundcard?
Actually, I guess since both the front and back panel don't work, it isn't just the MOBO internal sound right? The fishy thing for me is the fact that when I play a sound, the volume control picks up a signal. Usually when I have a sound issue, there is no signal. I'm at a loss.
Driver Expert
Power supply Expert
Windows 7 Expert
if you try to play a windows sound or something in windows media player or i tune do you get something suupecting the realtek panel try to switch the headphone from redirect to to independant and look if you got cut speaker when headphone is plug in
Driver Expert
Power supply Expert
Windows 7 Expert
try this go to advance mode and try switching the headphone from redirect to independant also uncheck cut speaker when headphone is plug
Driver Expert
Windows 7 Authority
My guess, at this point, is that the on-board audio adapter is defective. Could have been a short when connecting powered speakers or when you swapped your PSU. I suggest you disable the on-board sound in your BIOS and get a stand-alone audio card at this point.
WAIT! Before you do the above. Do you have a Linux CD or DVD by chance? If not, you can get one at :
http://www.ubuntu.com/download
Burn the ISO to a CD and then boot from the CD (into the Live or Try It selection, nothing will be written to you HDD). If the sound is working properly, Ubuntu will generate sound when it starts up. This "test" can verify of this is a hardware or software problem.
Thanks for all the help/advice both to scout_03 and COLGeek. I blew my last PSU so I wouldn't be surprised if the surge fried the adaptor. I think you're right, buying a sound card is the next step. I've ruled out all driver/setting issues. I'll let you know if that does the trick.
Well, it looks like you've done about all the debugging you can. Volume control is picking up a signal being played, so the system THINKS its sending out an audio signal...
Only thing I can think of is to make sure that SPDIF isn't set as the default output. Other then that, I'm at a loss.
Driver Expert
Windows 7 Authority
samburg said:
New Sound Card is in, sound restored. Must have been the on-board adapter. Thanks again all!
Good luck! Have fun!!
Ask the community
