hi im new to pc building and im looking to build my first pc. I have a couple of problems choosing a case, as some are very expensive, i was thinking of the Antec 1200 but thats probably too expensive at over £100. I was also considering the antec 900 but thats also a bit expensive at nearly £80 and i was worried whether my cpu cooler Corsair CAFA50 Air Series A50 Performance CPU Cooler. If it helps i would like to one day use two gtx560tis in sli.
my build
i5 2500k
gtx560ti (2 in the future)
8gb ripjaws ram
asus p8z77 mobo
seagate baracooda 1tb
Corsair CMPSU-750TXV2UK Enthusiast Series TX750 V2 High Performance 750W Power Supply
* this is quite expensive and a stretch on my budget and a cheaper case will help i think
my build
i5 2500k
8gb ripjaws ram
asus p8z77 mobo
