Solved
help with building gaming machine/video card help?
Approximate Purchase Date: today
Budget Range: 600-700 give or take
System Usage from Most to Least Important: pandora, netflix, hbogo, gaming, internet...i can't really put those in order since I may do all at the same time...aside from netflix and hbogo at the same time.
Parts Not Required: keyboard, mouse, monitor, possibly the video card ( to keep the cost down I have an HD 5450 that I can use in the mean time. I know it's not ideal but it still keeps the cost down for atleast this month.)
Preferred Website(s) for Parts: all from www.microcenter.com
Country: USA
Parts Preferences: by brand or type:
cpu ; http://www.microcenter.com/single_product_results.phtml?product_id=0388579
mobo : http://www.microcenter.com/single_product_results.phtml?product_id=0386373
RAM: http://www.microcenter.com/single_product_results.phtml?product_id=0355690
HDD: http://www.microcenter.com/single_product_results.phtml?product_id=0375261
dvd: http://www.microcenter.com/single_product_results.phtml?product_id=0382892
case: http://www.microcenter.com/single_product_results.phtml?product_id=0355148
wifi: http://www.microcenter.com/single_product_results.phtml?product_id=0383917
psu: http://www.microcenter.com/single_product_results.phtml?product_id=0365238
gpu: http://www.microcenter.com/single_product_results.phtml?product_id=0354216 or http://www.microcenter.com/single_product_results.phtml?product_id=0388182
OS: windows 7 home premium 64 bit.
Overclocking: no-maybe...I don't think overclocking is for me since I have never done it nor do I think I need to...convince me otherwise and we'll see.
SLI or Crossfire: no-maybe...again I don't think I'd do it, but this is a more likely scenario than OC
Monitor Resolution: I'll be honest I'm not sure what res 1080p is but that's what my 42" TV is, so whatever res puts out 1080p
Additional Comments: I only chose to use Microcenter due to how close it is to me and I haven't found all the parts cheaper online than here. Maybe I'm bad at looking for a deal online, but I also like yelling at the moron who sold me the crap I just bought...I can't do that with an online store. but once again if there is a deal so good that I'd be stupid to ignore it than I'm all ears. With the parts that I have selected I couldn't find a cheaper machine that would do more. I'm not an expert but i'd like to think that I atleast have a clue as to what is going on inside that metal box. (I've built all my other cpu's, This will be the first that I have (until now) asked an "expert" on which parts I should use.
Thank you for any help you can provide me.
-Slizz
5 answers Last reply Best Answer
More about help building gaming machine video card help
  1. I'm going to guess that no replies means that this system is good to go? maybe one more note...Is anything overkill? I'd like to make this purchase last a few years with the ability to upgrade as needed.
  2. Best answer
    Not sure about the case.
    That motherboard was made for a single card configuration. You can't crossfire/SLI with that motherboard.
    Some say that 600W is too much for a single card no overclock configuration.
    6850 is available for $140.79 on Amazon.
    http://www.amazon.com/gp/product/B004F6GJAU?linkCode=xm2&tag=invihand-20 (free shipping and no tax depending on where you live)
    Yeah I was thinking that the power supply was a bit much. But I'm all about value, I couldn't find another power supply in that price range that looked like it was as good. I'm not familiar with decent psu's first time I didn't just get the $20 version to make the machine turn on. Motherboard I'm not firm on either, just seemed like a good deal ($50 off of mobo with purchase of chip). So any mobo would work. I'm looking for one that I wont need to upgrade for years. Thanks for the info. Any suggestions?
    -slizz
  4. You should be fine with that mobo unless you plan on adding an afterstock CPU cooler, crossfire/SLI, or a large GPU (mars 2).
    Check GA-Z77X-D3H if you're interested in buying an ATX mobo.
  5. Best answer selected by slizz26.
New Build Graphics Cards Systems
