So I just completed my build and was wondering what programs you guys use to test and make sure everything is running 100%?
I haven't had any problems so far, so it's not like I am trying to solve any particular issue. I updated the bios and have all drivers installed and windows up to date. AV installed, the whole 9 yards.
What do you guys do to test performance and reliability, if anything? Prime95? 3DMark?
Basically, how do you make sure your components are working up to there capacity? And make sure temps aren't getting too high, especially if OCing? Is there a program for that that runs on the desktop? I see in the bios the CPU/Mobo temp is like 28C at idle.
