Hello, I've searched the forums and can't find anything that addresses this question.
I have a simple wireless network in my home run through a Linksys WRT54G Router connected to a cable modem. I set up a Western Digital 1TB external hard drive as a network drive through use of a Seagate FreeAgent DockStar. (The HD connects to the DockStar by a USB cable, which in turn connects to the router by an Ethernet cable.)
The hard drive functions as a network drive and I've configured Windows 7 Home Premium on my laptop computer to recognize it at start-up so it can essentially be used read and written to like a local drive.
Is there a way to make Windows 7, either by built-in software or third party software, automatically backup certain files or directories when changes are detected?
For example, I have a folder on my internal HD where I organize the vast amount of photos that I take so that I can easily find them through the operating system instead of having to go through a photo manager. In my ideal situation, something would be monitoring to see if I have made changes in only that folder (either adding new folders, deleting photos, or modifying files) and simultaneously make the changes to the network hard drive. Effectively, I want something to mirror the changes on my local hard drive on the fly and update the network hard drive accordingly. I do this all manually at the moment and it sucks up a lot of time that could probably be done automatically.
Thanks for reading. Any suggestions are appreciated.
