Hi all ,
Goal: I want to upgrade my system, so I can have 4 monitors.
Below is the current system and I need help with determining if I need a new PSU and what kind of mother board I should go with and so on.. I don't want to spend to much, however I do want the best value.
Comp Rig:
Mobo : ASUS M4A785TD-M EVO AM3 AMD 785G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813131406
PSU: OCZ ModXStream Pro 600W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
http://www.newegg.com/Product/Prod [...] 6817341017
RAM: G.SKILL Ripjaws Series 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH
http://www.newegg.com/Product/Prod [...] 6820231276
CPU : AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.com/Product/Prod [...] 6819103808
GPU: GIGABYTE GV-N460OC-768I GeForce GTX 460 (Fermi) 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Prod [...] 6814125334
CASE: Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811129042
SSD: SanDisk Ultra SDSSDH-120G-G25 2.5" 120GB ...
http://www.newegg.com/Product/Prod [...] 6820171545
Heatsink : COOLER MASTER Hyper 212 EVO
http://www.newegg.com/Product/Prod [...] 6835103099
Lastly, for mobo's with dual or multiple pci express whats the benefit of getting two with x8 or one at x4.. Just need some help with that.
Thanks
Comp Rig:
Thanks
