Graphics Card Help?
I have the following custom pc and I'm looking for a good graphics card that will not bottleneck my system. My processor is an Intel Core i3 2130, which is 3.4 ghz dual-core hyper-threaded. I have 4 GB ddr3 ram, a good 550 watt power supply, and a decent motherboard. I do not plan to sli or crossfire. Please answer with suggestions for nvidia and amd radeon.
4 answers Last reply
More about graphics card help
  1. you need to give a budget.
    I would recommend the geforce 560 ti or radeon 6870.
  2. BigMack70 said:
    What games do you want to play (and at what settings / resolution / fps)? How much money do you want to spend?
    Without that info, no way to help you.
    Resolution 1600 by 900
    Budget: anywhere up to $130
    Games: any on medium settings
    Specific enough?
    Specific enough?
  4. ok with that budget the 6770 is probably your best bet.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150540
Graphics Cards Graphics Product
