Can you use an ATX 12v 8-pin power connector on a 4-pin port?
Last response: in Components
- Can you use an ATX 12v 4-pin power connector on a 8-pin port? - Forum
- Safe to use an 4-pin to 8-pin 12v ATX power connector? - Forum
- Can i use 8-pin connector on 4-pin ATX 12v on my motherboard ? - Forum
- GIGABYTE 880GM USB3, 1 x 8-pin ATX 12V power connector, But I using 4 pin power connector. - Forum
- Motherboard has 4-pin ATX 12v connector and CPU 8pin, Help... - Forum
- Is it safe to use an 4-pin ATX connector for 8-pin ATX connection? Forum
- Can I use a 8-pin 12v connector on a 4-pin? Forum
- Can I use 8-pin 12v in my P35-DS3L 4-pin connector? Forum
- Do i have to use atx 20 4 motherboard connector and 12v 4-pin motherboard connec Forum
- Does using an 8-pin CPU power connector on a 4-pin board result in less amperage? Forum
- SolvedConverting 8-pin ATX 12V on PSU to 4-pin on CPU? Forum
- SolvedCan a 4-pin ATX connector work on the 8-pin atx motherboard. Forum
- 2x 4-pin ATX 12v in an 8-pin slot? Forum
- ATX 12V 4-pin and 8-pin Forum
- 4-pin vs 8-pin 12V connector Forum
- 4-pin vs. 8-pin 12V Connector? Quad Overclocking Forum
- SolvedCan i plug an 8-pin EPS 21V Cpu connector to a 8-pin ATX 12V Cpu header? Forum
- 8-pin v 4-pin ATX 12v - plastic cover over 4 of 8 pins Forum
- ATX 12v (4-pin) to EPS 12v (8-pin) adapter idea ok? Forum
- SolvedATX 24-pin ATX 12v 8-pin use them both or one? Forum
- More resources
Read discussions in other Components categories
