I recently just bought all new parts for a new computer. I got everything plugged in and installed. However the system will not turn on. I tried each stick of RAM in the 2nd slot, nothing changed. Checked the CPU and CPU cooler+cables, no effect. Checked the power cable on the PSU to the outlet plug and also all the power cables to the motherboard+HDDs,optical drive, etc. One thing is the motherboard did not come with any standoff screws, so with the CPU cooler attached the motherboard sits higher than the screws that were provided can reach. I managed to get 2 screws to screw into the bottom two corners of the motherboard. The motherboard does sit slightly slanted in the case. When I turn on the PSU the power button for the motherboard lights up and then I press the motherboard power button. Nothing happens, except the LED light for the case blinks once.
All parts purchased through Newegg.com
CPU= intel i-5 3570K
CPU cooler= Corsair Hydro H60
Case= Coolmaster HAF 932
PSU= Rosewill 1000W RBR1000-M
Motherboard= Gigabyte G1.Sniper 3
RAM= G.Skill Ripjaws 4x4GB DDR3-2133mhz
GPU= Galaxy GTX 670 2GB
Optical Drive= LG 12x Super Multi Blu-ray Rewriter WH12LS39
SSD= OCZ Vertex 4 128GB
HDD= Seagate Barracuda 3TB
Here are some pics of the system with everything plugged in.
https://www.box.com/s/6ec4aab5a05a168b3e79
