Archived from groups: microsoft.public.windowsxp.customize (More info?)
I have recently rebuilt my Dell Latitude C600. Before rebuilding my computer
my 2 smart batteries lasted over 2 hours each. After installing XP
Professional Operating System and Office 2003, the battery life has been
reduced to less than 5 minutes.
I do not think that it is a problem with my hardware, as it would be very
unlikely that both batteries would die at the same time. Only one of them
was in my computer while I was rebuilding it. I have seen an issue for XP
regarding Short Battery Life on Your Pentium III-M Tualatin Processor
Computer, but I have installed SP2 so this should not be an issue even if I
do have the hardware defined here.
Any help or guidance in how to fix this issue would be greatly appreciated.
> computer my 2 smart batteries lasted over 2 hours each. After
> installing XP Professional Operating System and Office 2003, the
> battery life has been reduced to less than 5 minutes.
> very unlikely that both batteries would die at the same time. Only
> one of them was in my computer while I was rebuilding it. I have
> seen an issue for XP regarding Short Battery Life on Your Pentium
> III-M Tualatin Processor Computer, but I have installed SP2 so this
> should not be an issue even if I do have the hardware defined here.
> appreciated.
Make sure you are right..
Boot with a DOS boot diskette from www.bootdisk.com (or CD) and see how long
it works in DOS.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
