Nokia 6600 ringing problem
Last response: in Brands
Archived from groups: alt.cellular.nokia (More info?)
Hi have a weird ringing problem with my Nokia.
Sometimes it don't ring for incoming call, sometimes it rings just for a few
seconds and then stops, as if I presses silence button.
Most of the times it works just fine, but the "other times" irritate me very
much.
This started happening after I flashed it to 4.09.1 firmware.
I read somewhere that I could format 6600 (reset it completely, to factory
settings). How do I do this?
10x
>much.
>10x
Normal Reset (*#7780#) : Restores ini files from rom
but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This reformats completely the
C: drive. All applications and files stored on this
drive will be lost and clean default files will be
rewritten.
Bye
Alberto
(Rome - Italy)
Ask the community
