Solved
Is my cabinet worth for handling geforce gts450 and corsair gs600 psu
i have an iball i6363 cabinet which is a normal pc cabinet. i wish to upgrade mypsu to corsair gs600 and i hav a geforce gts450 graphic card. Is my cabinet enough or whether i have to change my cabinet...??
12 answers Last reply Best Answer
More about cabinet worth handling geforce gts450 corsair gs600
  1. The GS600 is a good PSU but it is overkill for a system with a single GTS450. A good quality 400W PSU with at least one 6-pin PCIe power connector and 24A on the 12V rails would be sufficient. The Seasonic S12II-430 is more than sufficient and is a great PSU: http://www.flipkart.com/seasonic-s12ii-430-watts-psu/p/itmd5xz5bzevdbzp?pid=PSUD5XZ4PQNBPMES&ref=f81eae09-995c-4119-902e-2beeb15341ea If you intend on doing an SLI with the GTS450, then the SeasonicS12II-520 would work great: http://www.flipkart.com/seasonic-s12ii-520-watts-psu/p/itmd5xz5hzvzt9cx?pid=PSUD5XZ4KFH65H9E&ref=1ec79da1-f67e-47ee-b6f9-7919b5a2dd0e Both are also less expensive than the GS600.
  2. The case is simply a place to put our components; if you're happy with the case then that's the most important thing.
  3. thanks for the reply.. what about corsair gs500 or a cooler master thunder 500w psu..??
  4. Best answer
    The only Coolermaster PSUs that I would even think of considering are the Silent Pros. I've stayed away from crappermaster since they started using liar labels on their Extreme Power series of PSUs; any company that inflates ratings on their product so they can charge more money will not get my business. The Seasonic S2II-520 is a much better quality PSU than the GS series of PSUs from Corsair; if they are even close in price you should go for the Seasonic. I'd pay extra for the two extra years of warranty and higher quality of the Seasonic.
  5. thanks for ur help... i'm gonna go with the seasonic..
  6. Great choice - enjoy a really good PSU!
  7. but is this psu possible without an SLI on a single gts450....??
    but is the Seasonic S12II 520 Watts PSU possible without an SLI on a single gts450....??
  9. The Seasonic S12II-520 will support either a single GTS450 or an SLI of two GTS 450 GPUs. The Seasonic S12II-430 will support a single GTS450.
    i'll go with the Seasonic S12II-520... Thanks a lot for helping me... :)
  11. Best answer selected by adilkm.
  12. Glad I could help - enjoy a great PSU!
Power Supplies Graphics Cards Corsair Geforce Components
