Solved
First Build! looking for a bit of advice
Hi there everyone! Well straight to the point, as the title says this is going to be my first build and im just kind of looking for a little advice and input form you more experienced people with what I have chosen. I will be using this for games D3, BF, WOW, CS and a few others and with this rig hopefully able to obtain all them on ultra high setting so heres what i have
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027
mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
cpu- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
gpu- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604 (next month will sli and should it be OC?)
ram- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
hard drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
psu- http://www.newegg.com/Product/Product.aspx?Item=N82E16817152036
optical drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
monitor- http://www.newegg.com/Product/Product.aspx?Item=N82E16824009255 x3
Also just wondering if im going to need a few more fans also and if so what would you recommend? Thank you for your imput!
4 answers Last reply Best Answer
More about first build advice
  1. Fan-wise, I think you're going to be fine. That case appears to have a low front intake fan as well as a high rear exhaust. The additional venting and side-door fan should be more than enough to get good circulation through the case.
    Component-wise, the first thing that jumps out is the CPU/Motherboard selection. Is there any reason you're not going Ivy Bridge? Aside from that, it's a decent selection.
    The other thing that I'm not too crazy about is the power supply. Look for power supplies from Antec, Corsair, PC Power and Cooling, FSP (Fortran Source), or Seasonic.
    -Wolf sends
  2. Theres no real reason im not going ivy bridge from what I have herd the i5 2500k is a solid cpu what would be the benefits of the ivy bridge over sandy thanks for the reply.
  3. Best answer
    I agree with the power supply.
    I suggest one like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
    Be sure to not get a cheap PSU. That's going to be the thing powering your system and you want it to be one of the most reliable components in there.
    Also, I've dabbled about in GPU Overclocking and it's not really all that much worth it. The most I've ever gotten was a couple FPS better than what I originally had, and if you're planning on running that card in SLI with another one on a 23" monitor, then they'll destroy the games you're talking about without being tweaked in any way.
  4. Best answer selected by stillywilly.
Homebuilt World Of Warcraft Build Systems Product
