Will the Radeon 7750 work with this set-up?
Graphics card Expert
Just about any dedicated video card will work with your system. Whether it makes sense in using a high end GPU with your proposed system is another topic.
What is your budget for your system?
Did you have any other special requirements for your system?
I would recommend a z68 based mobo, if you want to have the most flexibility with your system in the future, otherwise you can get by with a bit cheaper option, if needed.
No, I'm trying to find a dedicated gpu for my existing system, the specs I gave are what I'm using right now, heh.
* Well having the PSU make and model will help a lot too.
* Your mobo isn't as critical to know, but definitely helps to tailor other parts. You can either open up your case and see what the model # is that is screen printed (usually) onto the mobo or you can find the box that it came in and get the info off of it.
* I'll still need to know what your budget is for the GPU, so I can recommend the best for your $.
Ask the community
