After Deployment Present Build (First Build)
Last response: in Systems
Approximate Purchase Date: October-November (currently deployed kind of a welcome home present for myself)
Budget Range: 2500-3500 (I've been deployed for a year I have a little money saved up but don't want to break the bank)
System Usage from Most to Least Important: Gaming, Video Editing, Music, Internet
Parts Not Required: Keyboard, Mouse, Speakers, Headset
Preferred Website(s) for Parts: Newegg, Amazon
Country: U.S.
Parts Preferences: No Preference
Overclocking: Yes
SLI or Crossfire: Yes
Additional Comments: Quiet is always good
Intel Core i7-3930K
ASUS RAMPAGE IV EXTREME
Cooler Master Silent Pro Gold 1200 Watt
ASUS GeForce GTX 680
16GB Series for Intel X79 (This one is a friends spare so it's not costing me. why he has a spare i don't know but hey free is free)
Cooler Master 1200 W silent
Samsung 830 SSD 256mb
Downgrade anything? Upgrade anything? Still need a tower.
Thanks in advanced.
Your budget is pretty high for what you're proposing, but can get some real killer items! Here is something I put together (please take the case even if not the build, it has amazing airflow):
CPU: Intel 3930k
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $590
CPU Cooler: V10 Hybrid (for some nice overclocking)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $116
MOBO: ASUS Rampage IV Extreme
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $430
Case: HAF X (942)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $200
+1 Case Fan on Top: Cooler Master 200mm Red Led Case Fan (will drop temps by about 3 degrees celsius)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $24
RAM: Your friends ;)
SSD: OCZ 240G (Your samsung is good, but this $20 dearer options will outperform. However, it is your choice)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $300
HDD: Western Digital Caviar Black 1TB 7200rpm
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $120
PSU: Cooler Master Silent Pro Gold series, 1200W 80+ GOLD (Amazing, clean power, only the finest for this system. By the way, you wouldn't need 1200W unless you were going quad SLI haha)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $240
Optical: LG Lightscribe Blu-ray read/write + 3D support
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $65
GPU: ASUS GTX 680 (nice choice)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $500
Grand Total = $2585
Now, onto the second issue. If you wish to remain at this price, which is right at the beginning of your budget, that is great. If you are willing to spend $500 more, obtain a second GTX 680 and let the world be at your feet (ok, that would be overkill haha)! Otherwise, you should obtain a monitor, which I didn't include (sorry if you don't have one). Here is my suggestion:
Monitor: Samsung Syncmaster 27" 2560x1440
http://www.newegg.com/Product/Product.aspx?Item=N82E168... - $850
Hope that this is what you were looking for! And for an OS, just get a 'free' copy of windows 7, or you can spend $100 if you feel the need!
Ask the community
