Hey guys I'm having a serious issue with my new computer and I am completely stumped at the moment. I built my new machine around christmas and it has been working flawless..until last night. I had the machine running while I was watching tv and I heard it make the windows startup noise. I went to check to see if it had installed any updates and restarted itself but when I tried to login but couldn't click in the password field. Then the screen turned on and off and showed a few characters I typed for my password and then nothing again. I was unable to click the power button or get into windows normally so I tried safe mode which worked fine. I tried disabling all startup programs and attempted to login normally with the same results. I decided I'd reinstall windows 7 since I didn't have anything important to lose. I also updated to the latest BIOS. After install I got into windows fine, installed my LAN drivers and windows installed an update for me and asked to restart so I did. Now I am faced with the exact same problem as before on a fresh windows install. It boots straight to my desktop since I no longer have my password and I am unable to interact with the desktop.
If anyone could PLEASE give me some help I would appreciate it so much. If it sounds like a hardware issue and I posted this in the wrong place please direct me to the appropriate forum. Sorry for the long post and thank you so much for your time.
SPECS:
MOBO-Asus P8Z68-V Pro
CPU- Intel Core i5 2500k @ stock
RAM- G.Skill Ripjaws X 8gb DDR 3 1600
SSD- 128gb Crucial M4 0009 firmware
HDD- Western Digital Caviar Black 1tb for storage
GPU- AMD Sapphire Radeon 6950 2gb Dirt 3 edition
PSU- 850w Cooler Master Silent Pro M 850w
OS- Windows 7 Home Premium 64bit
SPECS:
