If processor is ok then why monitor is not show display solution
i have a nicola motherboard 945 when i plug ram and cpu and new smps when i start it cpu fan and smps fan is run but no display on screen and i have change the ram also
3 answers Last reply
More about processor monitor show display solution
  1. Bad display cable?
  2. if it is Bad display cable according to u then how other motherboard is show it display another board is mercury pi945 series
    try it i hope solve my prob soon
  3. bad motherboard/cpu.. check first the capacitors on the motherboard. if its bulged like this
    u need to change each and every capacitor on board.. If there is no such thing, suspect ur motherboard itslef and/or cpu
CPUs RAM Processors Displays
