CPU motherboard combo please help
CPUs
Motherboards
- Product
Last response: in CPUs
jaylopez508
September 14, 2012 7:59:08 AM
http://www.newegg.com/Store/ComboDeals.aspx?ComboStoreI...
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
ratings? suggestions? what would u buy?
More about : cpu motherboard combo
noise
September 14, 2012 8:41:52 AM
jaylopez508
September 14, 2012 8:44:34 AM
- ***Please help with buying a Motherboard and CPU combo for 480 GTX*** - Forum
- Please recommend a good motherboard & CPU combo - Forum
- Please Help Me with My CPU-GPU-Mobo Combo - Forum
- Please Help Rate this CPU+GPU+Mobo Combo - Forum
- Help me choose a overclockable CPU/Motherboard/Memory combo - Forum
jaylopez508
September 14, 2012 8:45:11 AM
m
l
jaylopez508
September 14, 2012 9:02:40 AM
reasons? u like intel better? i would go for intel as well if i have the extra money but all that is going into a 660ti from msi,
psu and case
then ram and hard drive so yeah if i had an extra money i would
psu and case
m
l
jaylopez508
September 14, 2012 9:04:16 AM
maybe this one but that's just me MOBO:GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
m
l
noise
September 14, 2012 9:21:57 AM
It's just very hard to recommend something that you wouldn't buy yourself.
I don't think Newegg have them on combo-deal but how about an i3? (Or a non-k i5 if you could squeeze to it.) Even the slowest i3 is rated above the AMD chips:
http://www.tomshardware.co.uk/gaming-cpu-review-overclo...
m
l
Best solution
The combo with the FX 4170 is pretty good but you can do even better.Also the GTX 660 Ti is a really bad card for the money.You can get a HD 7950 instead which is faster, more overclockable, more future proof, with better compute performance and also much much better when using MSAA.
This is the cheapest, good HD 7950
And this is 20% faster.
Here is the best CPU + Motherboard combo you can do in this price range.
http://us.ncix.com/products/?sku=68355&vpn=BX80623I5238...
http://www.amazon.com/dp/B008KW62WK/?tag=pcpapi-20
And here is the one you should get if you really want an AMD CPU.
http://www.amazon.com/dp/B008V9959O/?tag=pcpapi-20
The reason why people advise you to buy a Intel CPU instead of an AMD one is because Intel's archetecture is more efficient.
Intels archetecture is on avarage 50% faster than AMD's FX per clock cycle.This means that a Intel processor clocked at 3 GHZ will be as fast as a AMD FX at 4.5 for single threaded tasks.
That's why even though AMD processors have more cores and those cores are clocked higher they still can't outperform their intel competitors.The only two AMD Processors that have unbeatable value are the AMD Phenom II X4 965 and AMD FX 8120.And they only shine once overclocked.
jaylopez508
September 14, 2012 11:45:47 AM
GTX 660 Ti beating a 7950 at 1920 resolution.
http://www.hardwarecanucks.com/forum/hardware-canucks-r...
http://www.techpowerup.com/reviews/MSI/GTX_660_Ti_Power...
http://www.anandtech.com/show/6159/the-geforce-gtx-660-...
Quote:
"As it stands, AMD’s position correctly reflects their performance; the GTX 660 Ti is a solid and relatively consistent 10-15% faster than the 7870, while the 7950 is anywhere between a bit faster to a bit slower depending on what benchmarks you favor. Of course when talking about the 7950 the “anything but equal” maxim still applies here, if not more so than with the GTX 670. The GTX 660 Ti is anywhere 50% ahead of the 7950 and 25% behind it, and everywhere in between.Coupled with the tight pricing between all of these cards, this makes it very hard to make any kind of meaningful recommendation here for potential buyers. Compared to the 7870 the GTX 660 Ti is a solid buy if you can spare the extra $20, though it’s not going to be a massive difference. The performance difference is going to be just enough that AMD is going to need to trim prices a bit more to secure the 7870’s position."
http://www.anandtech.com/show/6159/the-geforce-gtx-660-... Watch this video
http://www.youtube.com/watch?v=ibuXcStgYF8
m
l
jaylopez508
September 14, 2012 7:38:41 PM
jaylopez508
September 14, 2012 7:45:12 PM
Kamen_BG said:
The combo with the FX 4170 is pretty good but you can do even better.Also the GTX 660 Ti is a really bad card for the money.You can get a HD 7950 instead which is faster, more overclockable, more future proof, with better compute performance and also much much better when using MSAA.This is the cheapest, good HD 7950
so i think i will go with the The combo with the FX 4170 sounds most affordable and you said its pretty good?
m
l
jaylopez508
September 15, 2012 8:19:00 PM
jaylopez508
September 18, 2012 5:17:12 AM
hey guys i found a i5 2500K for 159.99
http://www.microcenter.com/product/354589/Core_i5_2500K...
is this a deal? and was thinking of the 965 BE
willing to spend the extra if the i5 is MUCH better for gaming
m
l
jaylopez508 said:
hey guys i found a i5 2500K for 159.99http://www.microcenter.com/product/354589/Core_i5_2500K...
I used to have an i5 2400k and that was better than my current 965be but tbh bro you wont see the difference past 60fps in games so if you want so save money but still play bf3 online in ultra get the 965be but if you want something which is just that bit more powerful go with the i5.
Both good cpus you will be very happy with either.
m
l
http://www.anandtech.com/bench/Product/102?vs=288
Some benches for your consideration.
It is possible to Oc the 965 to ridicules proportions so it will be ok even for a few years.
m
l
lhikary
September 18, 2012 2:42:23 PM
the comobs r not available anymore so i cant help u out dude
some help heere guys?
need some help here
http://www.tomshardware.com/forum/347868-28-thermaltake...
need some help here
m
l
jaylopez508
September 23, 2012 11:55:18 PM
lhikary said:
the comobs r not available anymore so i cant help u out dudesome help heere guys?
need some help here
m
l
- SolvedMotherboard/CPU Combo Help Forum
- SolvedNeed help with motherboard/CPU combo Forum
- Need help with selecting motherboard/CPU combo to build epic gaming PC Forum
- Please help with best overall CPU & GPU combo for the next 5 years Forum
- SolvedHelp choose an ITX Motherboard / CPU Combo Forum
- Need help finding a Good Motherboard/CPU Combo Forum
- Need help upgrading my motherboard cpu combo Forum
- Intel CPU and Motherboard combo help requested Forum
- SolvedPlease Help With Gaming Build (Motherboard and CPU) Forum
- SolvedWill cpu LGA 1150 fit a 1150 motherboard, need help quick, please Forum
- What CPU would be good with this GPU combo?-Please Help! Forum
- Need Help on Lower Watt CPU and Motherboard Combo? Forum
- Please Help: CPU + MB combo advice needed with budget Forum
- should i get this cpu/board combo? please help Forum
- SolvedWhat's a good CPU Motherboard Combo $350-$450 budget Forum
- More resources
