Sign-in / Sign-up
Need advice for this system
  • New Build
  • Silverstone
  • Systems
Last response: in Systems
May 23, 2012 7:29:30 PM
hi all, this is my first new build gaming system please give some advice about this build.
1)i5-3570k Cpu
2)MSI-Z77A-GD65 Mother B
3)Corsair 4x4GB 1600MHZ Memory
4)Samsung SSD 830 2.5'' H.D
5)GTX 680 2GB
6)Silverstone TJ08-E or Silverstone Raven 3
7)Power suppy ?
1)here is my question, how much power suppy do i need for above system ? and which is good.
2) which pc case?
thank you.
More about : advice system
May 24, 2012 12:45:25 AM
1: you dont need 16 gb of ram unless you are video editing. you can go with a set of crucial ballistix sport 8gbs
2: i have a mushkin chronos deluxe and it rocks at only around the 1$/gb mark. plus it uses the same nand as a vertex 3 max iops
3:get a gigabyte gtx 670. it is 100$ cheaper than a 680 while performing 5-8% less.
4: the silverstone case isnt compatable. i would personally go with a antec one or antec 302
5: a good power supply is a ocz zt550w. its fully modular and pretty cheap too. if you have more cash, i would definity go get a seasonic m12II 520w. 500-600 w is good enough for the single gpu. if you want to sli or crossire, get a 600-750w power supply
