Archived from groups: microsoft.public.windowsxp.customize (
More info?)
Thanks, you've helped to give me some insight in to the terminology used by
MSFT, and to dig deeper. Here's a "tool" I found for managing logon&logoff
scripts from a common point:
Start -> Run -> gpedit.msc -> Ok
Local Computer Policy -> Computer Configuration -> Windows Settings ->
Scripts (Startup/Shutdown)
You'll see what's going on once you get into the Scripts(Startup/Shutdown)
console. I'll play around with this.
Mike.
"a nonymous" wrote:
> "Michael" <Michael@discussions.microsoft.com> wrote:
> | I have two *.exe's I want the PC to run automatically. One executes when the
> | PC is turned on or comes out of standby. The second executes when the PC is
> | turned off or put into standby. Any white papers or how-to instructions?
> | My *.exe's send commands out of the COM2/RS232 port. I have a peripheral
> | attached to the RS232 that I want to turn off&on when the PC power
> | transistions.
> | "a nonymous" wrote:
> | XP Pro can easily be configured to run scripts at Startup and Shutdown.
> | I do not know about running scripts when going into, or coming out of Standby.
> | What about hardware control? Is the peripheral able to sense the
> | DataSet Ready or Carrier Detect or Clear To Send levels?
> | The HW control of the peripheral is very simple: RS232 with Tx,Rx&GND only --
> | it has none of the other control signals in the RS232 spec. I put the PC COM
> | port into a standard Null configuration.
> | If you have a link on embedding exe's to run at power up and down, could you
> | pass me a URL? (p.s. I'm not looking to run scripts, to me that implies
> | something like Java or Perl, I want to run compiled exe's).
> For XP Pro, not on a domain:
> 1) In a text editor (such as Notepad), create the script to launch your
> StartUp-Shutdown.EXE, e.g.,
> Path\to\StartUp-Shutdown.EXE
> - Save it in a folder of your choice or the Default Folder:
> C:\WINDOWS\system32\GroupPolicy\User\Scripts\Logon
> + With a .BAT extension as a batch file
> e.g., StartUp-Shutdown.BAT
> 2)
> Start
> Help and Support
> STARTUP SCRIPT
> Full-text Search Matches (11 results)
> 1. Assign computer startup scripts
> 2. Assign computer shutdown scripts
> 6. Scripts
> 9. Order of events in startup and logon
> REFERENCE
http://support.microsoft.com/?kbid=315245
> (How to Assign a Logon Script to a Profile for a Local User - XP Pro, not on a domain)
