I am purchasing two EVGA Geforce 560 TI 448 cores Classified Ultra Video cards.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130758
I want to increase the cooling capacity for the cards so they are less likely to overheat when I run them in SLI configuration. I was considering the Arctic Cooling Accelero Xtreme PLUS II Universal VGA Heatpipe Cooler.
http://www.frozencpu.com/products/14457/vid-173/Arctic_Cooling_Accelero_Xtreme_PLUS_II_Universal_VGA_Heatpipe_Cooler.html?tl=g40c21s66
I just want to make sure that this cooler will work if I am going to be running two of these cards in SLI. I don't wanna void my warranty installing them to find out they don't even fit the card or that with them installed the cards won't fit in the slots. lol
Has anyone used this cooler on a Classified card or another such card that would be similar?
I would also accept recommendations to other aftermarket coolers similar to this one. I cant afford to water-cool and I don't plan to OC the cards. Just wanna keep the temps as low as possible. I currently run a GTX460 and it runs around 70-78c under load in BF3. I'm worried that these two cards will run way hotter together and cause issues.
Any assistance you can provide will be much appreciated.
James Peek
James Peek
