My new/first build, your thoughts or suggestions?
Hey, let me know what you think, primary use for gaming
3930k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116492
$200 shipped from IREP
(yes I know the 3570k or 3770k works just as good for gaming, I'm getting it for 200 though and it will be better once games can utilize 6 cores)
AsRock extreme6 x79 mobo w/ game blaster sound card
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157290
$270
G skill RipJaws 4GB x 2 @1600mhz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
$47
Gigabyte gtx 670
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125423
$400
Kingwin 850w PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121069
Free from IREP
2TB seagate barracuda sata III 7200 rpm
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834
$120
Hyper 212 Evo
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
$35
NZXT phantom full tower case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
$130
Sony 18x DVD drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
$17
5 answers Last reply
More about first build thoughts suggestions
    3930k
    $270
    $47
    Gigabyte gtx 670
    $400
    Kingwin 850w PSU
    Free from IREP
    $120
    Hyper 212 Evo
    $35
    $130
    Sony 18x DVD drive
    $17
    Looks like it will be good..you will have quite the gaming rig haha
  2. As always, check the distance of the main RAM slots you'll be using to the CPU socket. The Evo's fan will likely hang over the first slot and block a DIMM with heat spreaders.
  3. Are you planning on oc'ing?
    Yes, probably only to 4.0-4.2 ghz
    Then the cm 212 evo is a great choice.
New Build Games Systems Product
